Mark_HAL
Nov 08, 2017Aspirant
Is there an updated VPN guide for Windows 10? (FVS336Gv2)
Since the October Windows 10 update, our Windows 10 VPN connections are not working. Is there an updated guide to setting up these connections? Below are links to the old guides showing Windows 7. ...
JohnC_V
Nov 16, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Mark_HAL
Nov 17, 2017Aspirant
I will try the suggested setup from the link but won't have time until next week. I will try to update the thread with my results.
