Mark_HAL
Nov 08, 2017Aspirant
Is there an updated VPN guide for Windows 10? (FVS336Gv2)
Since the October Windows 10 update, our Windows 10 VPN connections are not working. Is there an updated guide to setting up these connections? Below are links to the old guides showing Windows 7. ...
JohnC_V
Nov 16, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Mark_HAL
Dec 30, 2017Aspirant
So I finally got around to trying to fix the issue. I took a Udemy course on VPN and this helped me find the more detailed settings for VPN that are pretty buried in the current version of Windows 10. I iterated through trying all variations of those settings in the Windows 10 client and all of the stuff I could find for the Netgear side and it is still not working. I finally figured out all the right settings using the Netgear VPN client but we have used all of our licenses and would like to use the Windows 10 client for the few employees that don't have the Netgear client software.
Any further suggestions would be appreciated.
- Dec 29, 2016Retired_Member
