Mark_HAL
Nov 08, 2017Aspirant
Is there an updated VPN guide for Windows 10? (FVS336Gv2)
Since the October Windows 10 update, our Windows 10 VPN connections are not working. Is there an updated guide to setting up these connections? Below are links to the old guides showing Windows 7. ...
JohnC_V
Nov 16, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Mark_HAL
Feb 02, 2018Aspirant
Back on this again. We are having troubles. When I use the Prosafe client from home, the connection is pretty slow. I have another user I am setting up and I used the same parameters as mine but his won't connect.
Back to using the Windows 10 built-in client:
More googling found this Microsoft doc.
https://www.microsoft.com/en-us/download/details.aspx?id=54434
In section 4.1 it states that it only supports DH Groups 14, 19 and 20. When I am trying to setup my IKE policy on the firewall, only Groups 1,2 and 5 are available. It seems like this means I can't use the Windows 10 client with IKEv1. Is that correct?
Thanks
- Dec 29, 2016Retired_Member
