HansRL
Dec 29, 2021Apprentice
issue with GS308T connected with readynas 212 via LACP
I have issues with connecting my readynas 212 to switch GS308T via LACP. At the moment I connect the readynas all other connection freezes and/or loses their connection to the internet. I defined i...
- Dec 31, 2021
thanks for your support, yesterday I started all over, disconnecting all cables etc... , during that process i noticed some cables were mixed up. After reconnecting and reconfigure the GS308T everything is working as it should.
So my issue is solved.
thx again.
HansRL
Dec 30, 2021Apprentice
The firmware of my GS308T is up-to-date
in the commands you proposed I see nothing strange, the commands are given at the moment the NAS is connected to a router (and not to the siwtch)
IFCONFIG -a gives:
root@Geldrop:~# ifconfig -a
bond0 Link encap:Ethernet HWaddr b0:b9:8a:5d:ce:f2
inet addr:192.168.1.130 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MASTER MULTICAST DYNAMIC MTU:1472 Metric:1
RX packets:11488654 errors:22 dropped:1337008 overruns:0 frame:27
TX packets:7720651 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5006522075 (4.6 GiB) TX bytes:6258859308 (5.8 GiB)
eth0 Link encap:Ethernet HWaddr b0:b9:8a:5d:ce:f2
UP BROADCAST RUNNING SLAVE MULTICAST MTU:1472 Metric:1
RX packets:9598419 errors:3 dropped:1828 overruns:0 frame:3
TX packets:7289494 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:511986373 (488.2 MiB) TX bytes:1864575003 (1.7 GiB)
eth1 Link encap:Ethernet HWaddr b0:b9:8a:5d:ce:f2
RX packets:524927 errors:15 dropped:823313 overruns:0 frame:19
TX packets:2770 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:34733465 (33.1 MiB) TX bytes:304700 (297.5 KiB)
cat /proc/net/bonding/bond0 gives:
root@Geldrop:~# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2+3 (2)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP rate: slow
Min links: 1
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: b0:b9:8a:5d:ce:f2
Active Aggregator Info:
Aggregator ID: 3
Number of ports: 1
Actor Key: 9
Partner Key: 1
Partner Mac Address: 00:00:00:00:00:00
Slave Interface: eth0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: b0:b9:8a:5d:ce:f2
Slave queue ID: 0
Aggregator ID: 3
Actor Churn State: none
Partner Churn State: churned
Actor Churned Count: 0
Partner Churned Count: 1
details actor lacp pdu:
system priority: 65535
system mac address: b0:b9:8a:5d:ce:f2
port key: 9
port priority: 255
port number: 1
port state: 77
details partner lacp pdu:
system mac address: 00:00:00:00:00:00
oper key: 1
port priority: 255
port number: 1
port state: 1
Slave Interface: eth1
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: b0:b9:8a:5d:ce:f3
Slave queue ID: 0
Aggregator ID: 4
Actor Churn State: churned
Actor Churned Count: 1
port key: 9
port priority: 255
port number: 2
port state: 69
oper key: 1
port priority: 255
port number: 1
port state: 1
schumaku
Dec 30, 2021Guru - Experienced User
HansRL wrote:
in the commands you proposed I see nothing strange, the commands are given at the moment the NAS is connected to a router (and not to the switch)
Lot of things odd or strange. Trouble is we don't know anything about the router links and config, even less when problems arised.
As requested, I suggest to test the LAG with the switch, start with one active link only. Reboot the NAS before so the strange errors on the LAG and the interfaces are reset.
Marking some oddities hitting my eyes ... but again, with just two links connected to the router (and I guess no LACP config there):
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)Bonding Mode: IEEE 802.3ad Dynamic link aggregation
MII Status: up
Up Delay (ms): 0
Down Delay (ms): 0802.3ad info
LACP rate: slow
Min links: 1
Aggregator ID: 3
Number of ports: 1
Actor Key: 9
Partner Key: 1
Partner Mac Address: 00:00:00:00:00:00Slave Interface: eth0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
Aggregator ID: 3
port key: 9
port priority: 255
port number: 1
port state: 77
oper key: 1
port priority: 255
port number: 1
port state: 1Slave Interface: eth1
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
Aggregator ID: 4
port key: 9
port priority: 255
port number: 2
port state: 69
oper key: 1
port priority: 255
port number: 1
port state: 1
