HansRL's avatar
HansRL
Apprentice
Dec 29, 2021
issue with GS308T connected with readynas 212 via LACP
I have issues with connecting my readynas 212 to switch GS308T via LACP. At the moment I connect the readynas all other connection freezes and/or loses their connection to the internet. I defined i...
  • HansRL's avatar
    HansRL
    Dec 31, 2021
    @ schumaku Superuser Guru,
    thanks for your support, yesterday I started all over, disconnecting all cables etc... , during that process i noticed some cables were mixed up. After reconnecting and reconfigure the GS308T everything is working as it should.
    So my issue is solved.
    thx again.
ProSupport for Business
