scottbeattie
Jan 07, 2016Aspirant
JGS524Ev2 Password reset assistance
I've misplaced the password for my swtich and need to reset it. When I load the configuration utility I'm not able to factory reset it as it requires the password to do so. Is there a physical w...
DaneA
Jan 07, 2016NETGEAR Employee Retired
Hi scottbeattie,
Welcome to the community! :)
I believe there is a factory reset hole wherein you need to use a paper clip to press the reset button inside it for about 30 seconds. Have you already tried that?
DaneA
NETGEAR Community Team
scottbeattie
So I've tried thesde steps;
1 - pin reset to over 30 secs with power on, no result
2 - pull power out, hold reset button in, plug in power wait 10 secs
any other tips?
- JennCJan 08, 2016NETGEAR Employee Retired
Hello scottbeattie,
Please try this:
How do I log into the switch if I lost my password?
From the configuration utility, select the switch and use the serial number (printed on the bottom product label of the switch) as the password. Once logged into the switch, reset the password.
Source: http://kb.netgear.com/app/answers/detail/a_id/12048/~/prosafe-plus-switches-faq
Hope this helps.
- scottbeattieJan 09, 2016Aspirant
I've tried this also ... the serial number is not accepted as the password.
- JennCJan 09, 2016NETGEAR Employee Retired
Hello scottbeattie,
What's the version of the Prosafe Plus utility are you using?
