icotera
Jun 12, 2018Aspirant
Jumbo frames being dropped on M5300
I enabled jumbo frames on the switch by issuing mtu 9216 command on all of the interfaces. Connectivity works - two connected hosts ping each other - unless I increase the packet size over the standa...
Retired_Member
Jun 14, 2018Hi icotera,
Welcome to the community!
As the MTU config include L2 MTU and L3 MTU concept, not sure what's your config on the port. So could you please share your detailed config?
It's better if you can provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
http://kb.netgear.com/app/answers/detail/a_id/31439
Another question: Does the two host IP is in same subnet?
Hope it helps!
EricZ
NETGEAR employee
- icoteraJun 14, 2018Aspirant
Thank you very much for your response.
I tried both:
interface 1/0/6
set igmp
mtu 9216
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 10
vlan pvid 10
ip mtu 9000
It's better if you can provide the tech-support file of the Switch:I guess it will contain a lot of sensitive info, so I very much would like to avoid this.
Yes.
- Retired_MemberJun 14, 2018
Hi icotera,
Could you please show the packet statistics of the port? Just follow below steps (keep two host ping each other with jumbo frame):
clear counters all
(wait about 1 minute)
show interface counters
show interface 1/0/6
show interface ethernet 1/0/6
