icotera
Jun 12, 2018Aspirant
Jumbo frames being dropped on M5300
I enabled jumbo frames on the switch by issuing mtu 9216 command on all of the interfaces. Connectivity works - two connected hosts ping each other - unless I increase the packet size over the standa...
icotera
Jun 14, 2018Aspirant
Thank you very much for your response.
As the MTU config include L2 MTU and L3 MTU concept, not sure what's your config on the port. So could you please share your detailed config?
I tried both:
interface 1/0/6
set igmp
mtu 9216
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 10
vlan pvid 10
ip mtu 9000
It's better if you can provide the tech-support file of the Switch:
I guess it will contain a lot of sensitive info, so I very much would like to avoid this.
Another question: Does the two host IP is in same subnet?
Yes.
Retired_Member
Jun 14, 2018Hi icotera,
Could you please show the packet statistics of the port? Just follow below steps (keep two host ping each other with jumbo frame):
clear counters all
(wait about 1 minute)
show interface counters
show interface 1/0/6
show interface ethernet 1/0/6
- icoteraJun 14, 2018Aspirant
- Retired_MemberJun 14, 2018
Hi icotera,
Thanks for your immediately response. I notice there is some 'Unacceptable Frame Type' pasket statistics on the ethernet port.
1. So could you please introduce your network topo?
2. Does the two host connect to the switch directly?
3. Does the two host in same VLAN?
4. And please share the command for jumbo frame ping on your host.
5. Could you please try to ping switch IP address with jumbo frame?
Total Received Packets Not Forwarded........... 66
802.3x Pause Frames Received................... 0
Unacceptable Frame Type........................ 66
