jnoose
Jun 04, 2018Aspirant
Letter of Volatility GS724T
Howdy,
I know this has been solved elsewhere but all the links have expired. Can someone please send a new link to Letter of Volatility for the GS724T?
Thanks,
Justin
Hi jnoose,
No need for a specialized software to fully reset the switch. Resetting it to factory default would suffice and NETGEAR doesn't provide any specialized software in order for the switch to cleared out. Maybe it was just pointing to the Smart Control Center.
- JohnC_VNETGEAR Employee Retired
Hi jnoose,
Welcome to our community!
Here is the latest letter of volatility for GS74T. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- jnooseAspirant
Thank you so much for the quick turn around on this! Follow up question - where would I find the "specialized software utility" to clear the non-volatile flash memory on this switch? In my environment, the switch either needs to be fully sanitized or destroyed.
