clalove
Mar 02, 2016Follower
Limit big amount of "multicast packets received" on single port
3 x STACKED GS748TS
BOOT VERSION 1.0.2.0
SOFTWARE VERSION V 5.2.0.11
Server Ubuntu 12.04, Service CUPS 1.5.3
AP Ruckus 7372 - firmware 9.8.3.0.14
The AP stop propagate the printers over the IPP protocol, turn off and on the radio on ruckus and the IPP protocol return alive, this happens every 3 weeks!
After some troubleshooting, the ruckus support pointed me to check the Multicast package and infact there are very high, I tried to set enable Storm Controll on the port with Broadcast Mode > BroadCast, Multicast and Broadcast Rate Threshold to "3500",
I still have the same issue, any suggest ?
thank you
1 Reply
- DaneANETGEAR Employee Retired
Hi clalove,
Welcome to the community! :)
Have you tried to double-check the physical connections? If not yet, kindly check the ethernet cables because there might be a loose ethernet cable that is causing the problem.
DaneA
NETGEAR Community Team
