luizluca
May 02, 2018Aspirant
Limited number of IPv6 NDP entries
When I configure SDM to use dual-stack (IPv4 and IPv6), I do expect to use both.
However, at least with firmware 11.0.0.31, I get this limits:
(switchcore) #show sdm prefer The curren...
Retired_Member
May 08, 2018Hi luizluca,
Welcome to the community!
The maximum ARP/NDP counters is depended on different SDM template.
Login the switch by GUI(HTTP/HTTPS), go to 'System'-->'Management'-->'SDM Template Preference', you will see:
1. 'IPv4 Data Center Plus with IP Multicast Support': the 'ARP Entries' is 6144, and the 'IPv6 NDP Entries' is 0;
2. 'IPv4 Data Center Plus without IP Multicast Support': the 'ARP Entries' is 6144, and the 'IPv6 NDP Entries' is 0;
3. 'Dual IPv4 and IPv6 Data Center Plus with IP Multicast Support': the 'ARP Entries' is 4096, and the 'IPv6 NDP Entries' is 1024;
4. 'Dual IPv4 and IPv6 Data Center Plus without IP Multicast Support': the 'ARP Entries' is 4096, and the 'IPv6 NDP Entries' is 1024;
That's mean: if chose dual v4/v6 SDM template, the maximum 'ARP/NDP' counter is 5120; if chose only v4 SDM template, the maximum 'ARP/NDP' counter is 6144;
Hope it helps!
EricZ
NETGEAR employee
luizluca
May 08, 2018Aspirant
Retired_Member, thanks for your answer. However, I'm still confuse. You mentinoned "maximum 'ARP/NDP' counter is 5120;" but table shows ARP as "4096" and NPD as "1024". You say that they share a common limit of 5120 (4096+1024)? Aren't they independently managed or NPD can borrow entries from ARP?
- Retired_MemberMay 09, 2018
No, not share the table size. Just independent for v4 and v6, 4096 ARP table and 1024 NDP table.
- luizlucaMay 11, 2018Aspirant
Sorry Retired_Member, but I my questions are still open:
What will happen when "IPv6 NDP Entries" is exausted?
Now I have 4096 (ARP) and 1024 (NDP) entries while specs says I have "6K ARP/NDP". Are specs wrongs? Have it changed without metioning in firmware changelogs?
- Retired_MemberMay 14, 2018
Hi luizluca,
It's just different understanding. Actually, SPEC describe the maximum 6k APR/NDP entries, just meaning supported in specific SDM template. It's not meaning will support total 6K ARP/NDP entries in every SDM template.
Hope it can helps!
