yakamoneye19
Oct 29, 2018Aspirant
"Link State Tracking" Feature on NEtgearSwitches
Hello everyone,
we are using two M7100-24x-Switches for our VMWare traffic. The complete networking of the vm is redundant - any network card or any of the swichtes can fail, and vmware will st...
- Oct 29, 2018
Hi yakamoneye19
Thank you for your message. We don't have such a feature like this in the M7100 series, unfortunately.
We implemented this feature in the M4300 series under the name Link Dependency Feature: the Link Dependency feature enables or disables one or more ports based on the link state of one or more different ports.
I would advise the M4300-24X or any other 10G model in the M4300 series:
yakamoneye19
Oct 30, 2018Aspirant
Hello Laurent,
thank you for your response.
Just to be sure: is this feature exclusively for the 4300 series at the moment? Are there any plans to include them to other series like 7100 by update?
Thanks
Tobias
LaurentMa
Oct 30, 2018NETGEAR Expert
Hi yakamoneye19
The Community is glad to help.
No, the Link Dependency Feature shouldn't be ported to M7100 which is running an ancient branch of our software code - this will have to stay exclusive to 12.x software.
If you want to explore how to upgrade your M7100 installation with new M4300 models, you can send me a message with your contact/details using private message. I will connect you with the local NETGEAR team, based on our location. I'm sure we can find a way.
- yakamoneye19Oct 30, 2018Aspirant
Hello Laurent,
thank you for clarification.
The technical implemention would not be the problem, we need to find the money to buy...
Thanks
Tobias
