mbkitmgr3's avatar
mbkitmgr3
Link UP/Down events on select inactive ports M4100-24G-POE+
We recently included this device in our SNMP moitoring system
Every few seconds ports report Link UP/Iink DOWN on ports not yet connected to any devices. The other oddity is that some report this more frequently than others.  For example
Port 14 - every few secomds
Port 9 - a few times a day
Firmware Ver : 10.0.1.27
UPtime           : 484 days 23 hours 40 mins 57 secs
Is ther a known issue here, we receive thousands of emails a day from the SNMP alerts, and I dont want to diable notifications in case one is genuine.  What do I do here?
  • Retired_Member's avatar
    Retired_Member
    Hi mbkitmgr3
    Welcome to the community!
    May I ask some quesiton for further more analysis this problem?
    1. As the image of the switch M4100 is too old in your network, could you please upgrade to latest image and try again?  new iamge download link is image
    2. If the problem still occur after upgrade image, Could you please provide the tech-support file of the switch for further more analysis?
    How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
    http://kb.netgear.com/app/answers/detail/a_id/31439
    Hope it helps!
    EricZ
    NETGEAR employee
    • mbkitmgr3's avatar
      mbkitmgr3
      Hi EricZ,
      Thanks for your assistance with this task.
      I was able to arrange an outage last night to update the firmware V10.2.0.26.  From a check this morning the behaviour hasn't changed.
      I also receive advice from the device when I try to obtain the Tech Support log that it "is either empty or not found".  Is there something in the config of the switch that I have missed for the device to report this.
      I have downloaded any log/scripts/configs etc that would succeed and will submit them via the method requested
        Retired_Member
        Hi mbkitmgr3,
        You can run CLI command as 'show tech-support' first on console port or telnet port, and try again.
        Hope it helps!
ProSupport for Business
