milp
Jan 19, 2023Tutor
Linking two linux machines together. Do I need LAG or no LAG configuration on Netgear switch?
I'm a bit unsure on if and how I should configure an LAG. Scenario: I have two linux machines (names "linuxA" and "linuxB", hardware supermicro, OS CentOS đ linked together via direct cable in ...
schumaku
Jan 19, 2023Guru - Experienced User
The mentioned slow LACP Rate does set how how fast the bonded interfaces should transmit LACPDU packets. The default is every 30 seconds, characterized by the lacp_rate value of "0" or "slow", or every second, characterized by the lacp_rate value of "1" or "fast". This has no impact on the possible bonding link (LACP) performance.
milp
Jan 20, 2023Tutor
Thanks schumaku , I know what LACP rate is (frequency of LACP PDU updates sent via the link) and that it has nothing to do with the LAG speed. I was just interested where to configure this on a Netgear.
Apparently it only works by CLI and setting "lacp_rate". Thanks for the hint.
Any idea on the other questions?
Thanks
Dan
