DBestoso's avatar
DBestoso
Initiate
Jul 02, 2024
Loss of Local Clock Source setting upon reboot.
We've got 6 of these switches in an isolated network that has no connection to the Internet for AV production only.  We've turned off SNTP and have tried setting the time to local, but several of the switches continue to revert back to the date that they were brought online instead of keeping the correct date and time that was manually set.  We also tried to use a Windows 10 workstation, also on the isolated network, as an SNTP server for the switches, but enabling Windows Time on the Workstation isn't giving the Switch access to the time server on that system.  We are trying to prevent having to manually set the date and time on these switches every time one of them experiences a reboot.  We are also getting the following error message in the logs when we set the time to Local:  "INFO Local time change event received, but could not rename reboot sequence directory in USB drive."
  • schumaku's avatar
    schumaku
    To my knowledge, all Netgear (AV) switches depend on SNTP. For this reason, we're carrying a small NAS and/or a 4G-/5G-Router on all deployments.
    About AV Design Center support: The 24/7 service can be accessed via contacting NETGEAR through the email proav.engineeringservices@netgear.com.
    • DBestoso's avatar
      DBestoso
      Initiate
      I ended up turning one of the Workstations that have access on this network to an SNTP server and pointed the switches to that.  They all are golden upon reboot now.
ProSupport for Business
