off
Mar 19, 2016Tutor
Low fan speed - high temperature
With factory default Firmware Version 6.1.0.12 fan speed was always high and noisy. I install latest 6.1.0.34 and fan speed immediately reduced. I think that fan speed is now smart and will raise tog...
DaneA
Mar 20, 2016NETGEAR Employee Retired
Hi off,
Welcome to the community! :)
Kindly answer the questions below:
a. Have you already reset the XS712T back to factory default settings after successfully upgrading the firmware to v6.1.0.34? If not yet, kindly do it then reconfigure it from scratch.
b. Is the fan speed low with temperature being high even if the XS712T is not connected to your existing network.
c. What is the behavior of the Fan LED light?
I look forward to your response.
DaneA
NETGEAR Community Team
