grandfinalemike
Dec 21, 2023Aspirant
M4100 12GF - home use setup
ive been trying to gather information on whether I can configure my m4100 to connect directly to my comcast arris modem. And using the dhcp server option on the 4100, distribute ips to my network. ...
- Dec 22, 2023
Hi grandfinalemike ,
I'm the product manager for the www.netgear.com/managed switches.
There will be no NAT in the managed switch, so you cannot "replace" a router by a managed switch this way. NAT is needed, the managed switch will only allow for LAN routing, for instance between VLANs, but firewalling/NAT is still needed above, connecting to the ISP modem.
I hope this will help you!
LaurentMa
Dec 22, 2023NETGEAR Expert
