onyangodt
May 17, 2017Aspirant
M4100 12GF Firmware
Greetings, I have recently upgraded the firmware on my M4100 12GF (GSM7212F Layer 2+ ) switch. The switch will not save any configurations and everytime I reboot the switch it does not save the ...
- May 18, 2017
Hi onyangodt,
Very strange...
Maybe the flash is broken on this M4100.
Please check private message for maintenance commands.
Thanks.
DanielZhang
May 18, 2017NETGEAR Expert
Hi onyangodt,
Welcome to NETGEAR community!:smileyhappy:
It seems that this M4100-12GF don't have enough space on flash.
I suggest you to clear the unused data on it.
The data can't recover after following operation.
So please think about it carefully before do following operation.
1. Clear the log on flash by CLI
These log just used for NETGEAR support.
No harm to M4100.
Cleare crashlog
Clear event and trap log.
2. Clear scripts on flash by CLI
Input the script name which youo want to delete.
Or input delete all to remove all scripts on flash.
3. Clear the persistent log on flash by GUI
4. reload M4100 and try to save configuration again.
May the solution help you.:smileyhappy:
Thanks.
onyangodt
May 18, 2017Aspirant
It wont let me erase startup config nor factory defaults and weather I use write of save it wont save at all. Is there anyway I can rewrite the image1.stk or image2.stk? Is there anyway that I can reset it to factory defaults as if it was out of the box ? I use the clear config command to default it as well as the webgui but it still wont save after ive gone through the ezconfig prompt.
- DanielZhangMay 18, 2017NETGEAR Expert
Hi onyangodt,
Factory default operation won't clear flash so the space on this M4100 can't release at all.
We need to release more space on flash for this M4100 to make “save” operation work.
Could you please reference above solution to delete files on flash by manual?
- onyangodtMay 18, 2017Aspirant
I've followed the above solution that you provided and still I get the same messages indicated in the above console screenshots. Is there another solution ?
Hi onyangodt,
Okay.
Let's try another solution.
Try to Delete the unused image.
1. Check current active image.
2. Delete the unused image.
3. Reload.
Please reference following screenshot about commands of CLI.
I will send you some maintenance commands through private message if this new solution won't work.
