Luciano63
Dec 31, 2022Star
M4100-24G-POE+ ProSafe 24-port Gigabit L2+ Managed Switch with PoE+ - DHCP server
Hello everybody. I need to setup a DHCP server on the switch mentioned in subject. Following what is actually depicted in manuals leads to a non working configuration. So I was wondering if someone w...
- Dec 31, 2022
SOLVED: I solved the problem with some try & error - below the steps which solved my problem if anyone else should need them:
Go to Routing section and then choose "VLAN Routing"
- Add a new route for the VLAN on which you want to activate the service
- Choose the VLAN ID from the list
- In the IP adress field I added the first address of the excluded range
- In the subnet mask field add the VLAN mask
- Click on the "ADD" button to add to switch configuration
The REAL problem is that the CLI example in the software administration manual does not match the web interface one
Happy new year
Luciano
Luciano63
Dec 31, 2022Star
Happy new year
Luciano
