werwerfmsdf
Dec 08, 2022Initiate
M4100-26G IP Subnet based VLANs
I have a Netgear M4100-26G, running firmware version 10.0.2.20.
I am interested in connecting the three computers seen in the picture between two VLANs.
I would like
VLAN 2:
- PC 1
- PC 2
and
VLAN 3:
- PC 2
- PC 3
I would like all ports to be untagged. I read that traditional static ports can only have a single untagged VLAN associated with them. In my understanding, a way to get around this problem is to use IP Subnet Based VLAN Configurations.
In my switch I went to Switching -> VLAN -> Advanced -> IP Subnet Based VLAN and created two new rules:
1) 192.168.1.0 / 255.255.255.0 / VLAN 2
2) 10.0.0.0 / 255.0.0.0 / VLAN 3
A few questions:
1) In my understanding, traffic arriving at the switch from PC 2 will be assigned the appropriate VLAN by this rule. Traffic from PC 1 and PC 3 can have a known VLAN a priori. Do I need to create static VLANs under Switching -> VLAN -> Advanced -> VLAN Configuration for VLAN 2 and 3 and then assign "U" to their ports in Switching -> VLAN -> Advanced -> VLAN Membership? If so, does having static VLANs and dynamic VLANs with the same numbers cause a conflict?
2) It's my understanding that I will need to enable GVRP mode (Switching -> VLAN -> Advanced -> GARP Switch Configuration). For the dynamic VLAN required for the IP subnet based approached to work. Is this correct?
3) Next, I go to Switching -> VLAN -> Advanced -> GARP Port Configuration. Here, do I need to enable "Port GVRP Mode" for Port 2 only or for all three ports (1,2,3)? My understanding is that only port 2, connected to PC 2, is doing anything dynamically.
4) I found an option for "Dynamic VLAN Creation Mode" in Security -> Port Authentication. I have enabled this.
I was able to get this working. To do this, I:
1) In Switching -> VLAN -> Advanced -> VLAN Configuration, I created two new static VLANs, 2 and 3.
2) In Switching -> VLAN -> Advanced -> VLAN Membership, I made ports 1 and 2 untagged members of VLAN 2. I then made ports 2 and 3 untagged members of VLAN 3.
3) In Switching -> VLAN -> Advanced -> IP Subnet Based VLAN, I created two new rules
- 192.168.1.0/24 -> VLAN 2
- 10.1.1.0/24 -> VLAN 3
This appears to give me the configuration I wanted.
To answers my questions:
1) Dynamic VLANs were not needed. I mistakenly thought they were required for IP subnet rules to be in effect.
2) GVRP was not needed.
3) Also not needed.
4) Also not needed.
1 Reply
- werwerfmsdfInitiate
3) Also not needed.
4) Also not needed.
