some
Mar 23, 2019Initiate
M4100-26G-POE - Loaded factory defaults and now POE Status is Off
Loaded factory defaults. After load I am able to configure everything that need on the switch, except POE status. I am using the web UI and not command line. I am not familar with command line.
- Mar 30, 2019
Thanks for the help.
I did update the firmware to the latest version.
Problem found: Rookie mistake. POE is not offered on ports 25-26. I moved to port 24 and bam. The POE enabled device powered on and the system shows the POE status as running.
DaneA
Mar 24, 2019NETGEAR Employee Retired
Hi some,
As I have double-checked the M4100 user manual here, there is no setting to globally turn on the PoE Status.
The current firmware of your M4100-26G-POE switch is already outdated, I suggest you update the firmware to the latest version which is v10.0.2.26. You can download it here.
DaneA
NETGEAR Community Team
msi
Mar 26, 2019Luminary
I wanted to add that on an M4100 switch I recently saw PoE off when no PoE device were attached to, so this might be one aspect. Updating to the latest version is certainly a good idea. The M4100 line doesn't get much updates these days anyway.
I have an M4100 on 10.0.2.26 which runs PoE firmware 1.8.0.1. After the reboot into the new firmware PoE will remain switched off and you'll see a message about a PoE firmware update being executed. Until that process finishes, the PoE board will not power any attached device. This should take between 10-20' if I remember correctly.
Also it is quite likely that you may have to wait 10-20' after the reboot into an update firmware since the M4100 had some
