some's avatar
some
Initiate
Mar 23, 2019
M4100-26G-POE - Loaded factory defaults and now POE Status is Off
Loaded factory defaults. After load I am able to configure everything that need on the switch, except POE status. I am using the web UI and not command line. I am not familar with command line.   ...
  • some's avatar
    some
    Mar 30, 2019
    Thanks for the help.
    I did update the firmware to the latest version.
    Problem found: Rookie mistake. POE is not offered on ports 25-26. I moved to port 24 and bam. The POE enabled device powered on and the system shows the POE status as running.
