sachac14
Dec 13, 2017Aspirant
M4100-26G-POE V1H1 Need to setup two DHCP scopes 1 data and 1 voice, how to set this up.
Hi Guy's Hope you are all well, I need to setup two DHCP scopes 1 for data and 1 for voice. Scenario: I have Cisco ASA, Cisco Router, and 2x M4100-26G-POE V1H1 managed switches. I have VLAN 21 my ...
- Dec 13, 2017
Hi Sachac,
Welcome to NETGEAR community!:smileyhappy:
I just want to confirm the scenario that you want to deploy.
PC---IP Phone---[A]M4100[B]---[Server]
Please reference following step to deploy about scenario if that is you want.
1. Create VLAN for PC and IP Phone.
2. Add port A into the VLAN for PC and PVID also need to set.
Such as: PVID 14, Untag 14.
3. Set AutoVoIP VLAN.
Such as: 21
4. Enable OUI base AutoVoIP on port A.
5. Add OUI Mac for your IP phone.(M4100 has some default OUI)
6. Set VLAN for port B to carry trunk 802.1Q tag traffic.
You should also set same 802.1Q tag on peer devices/servers.
Such as: PVID 14, tag 14,21.
7. You can also configre DHCP server on M4100.
Just like create VLAN routing interface for VLAN 14,21.
Then set IP address for both VLAN.
Create DHCP Pool for both VLAN with correct IP address subnet.
8. Connect IP phone to M4100.
You will see that the Mac address of IP phone will put into VLAN 21 and Mac address of PC put into VLAN 14 on port A.
That will help you deploy this scenario work correctly.
Thanks,
Daniel.
Retired_Member
Dec 13, 2017Hi sachac14,
Welcome to the community!
We need more detailed info for your network, would you please answer some questions as below:
1. Which device works as DHCP Server? Cisco ASA or Cisco Router? Do you setup two DHCP Pools for these two VLANs(data and voice)?
2. On M4100 Switch, you need assign some ports(connect to data PCs) to VLAN 14(untag mode, and PVID=14), and assign some ports(connect to voice phone) to VLAN21(untag mode, and PVID=21). And I suggest you set VLAN 21 to Voice VLAN(Web GUI login the switch, go to 'Switching'-->'Auto-VoIP'-->'OUI-based').
3. On M4100 switch, for uplink port to DHCP Server, you need to assign this port both to VLAN 14 and VLAN21(untag or tag, up to the config on DHCP Server connect port).
If you finish the steps setting above, then please try again and check if the Phone working normally?
Hope it helps!
EricZ
NETGEAR employee
