sachac14's avatar
sachac14
M4100-26G-POE V1H1 Need to setup two DHCP scopes 1 data and 1 voice, how to set this up.
Hi Guy's Hope you are all well, I need to setup two DHCP scopes 1 for data and 1 for voice. Scenario: I have Cisco ASA, Cisco Router, and 2x M4100-26G-POE V1H1 managed switches. I have VLAN 21 my ...
  • DanielZhang's avatar
    Dec 13, 2017
    Hi  Sachac,
    Welcome to NETGEAR community!:smileyhappy:
    I just want to confirm the scenario that you want to deploy.
    PC---IP Phone---[A]M4100[B]---[Server]
    Please reference following step to deploy about scenario if that is you want.
    1.   Create VLAN for PC and IP Phone.
    2.   Add port A into the VLAN for PC and PVID also need to set.
    Such as: PVID 14, Untag 14.
    3.   Set AutoVoIP VLAN.
    Such as: 21
    4.    Enable OUI base AutoVoIP on port A.
    5.   Add OUI Mac for your IP phone.(M4100 has some default OUI)
    6.    Set VLAN for port B to carry trunk 802.1Q tag traffic.
            You should also set same 802.1Q tag on peer devices/servers.
    Such as:  PVID 14,  tag 14,21.
    7.    You can also configre DHCP server on M4100.
    Just like create VLAN routing interface for VLAN 14,21.
    Then set IP address for both VLAN.
    Create DHCP Pool for both VLAN with correct IP address subnet.
    8.     Connect IP phone to M4100.
    You will see that the Mac address of IP phone will put into VLAN 21 and Mac address of PC put into VLAN 14 on port A.
    That will help you deploy this scenario work correctly.
    Thanks,
    Daniel.
