sachac14
Dec 13, 2017Aspirant
M4100-26G-POE V1H1 Need to setup two DHCP scopes 1 data and 1 voice, how to set this up.
Hi Guy's Hope you are all well, I need to setup two DHCP scopes 1 for data and 1 for voice. Scenario: I have Cisco ASA, Cisco Router, and 2x M4100-26G-POE V1H1 managed switches. I have VLAN 21 my ...
- Dec 13, 2017
Hi Sachac,
Welcome to NETGEAR community!:smileyhappy:
I just want to confirm the scenario that you want to deploy.
PC---IP Phone---[A]M4100[B]---[Server]
Please reference following step to deploy about scenario if that is you want.
1. Create VLAN for PC and IP Phone.
2. Add port A into the VLAN for PC and PVID also need to set.
Such as: PVID 14, Untag 14.
3. Set AutoVoIP VLAN.
Such as: 21
4. Enable OUI base AutoVoIP on port A.
5. Add OUI Mac for your IP phone.(M4100 has some default OUI)
6. Set VLAN for port B to carry trunk 802.1Q tag traffic.
You should also set same 802.1Q tag on peer devices/servers.
Such as: PVID 14, tag 14,21.
7. You can also configre DHCP server on M4100.
Just like create VLAN routing interface for VLAN 14,21.
Then set IP address for both VLAN.
Create DHCP Pool for both VLAN with correct IP address subnet.
8. Connect IP phone to M4100.
You will see that the Mac address of IP phone will put into VLAN 21 and Mac address of PC put into VLAN 14 on port A.
That will help you deploy this scenario work correctly.
Thanks,
Daniel.
sachac14
Hi Daniel
Wow! Thank you for the prompt reply. Yes it is awsome to be here I am a Newbie to Netgear switches and have spent the last week gettting familiar wirth the product. My deadline for deploment is coming soon so I really need to get this working in my lab fist. I did not exspect a reply so I kept my question simple.
Toplopgy: PC>>Phone>>Switch2[M4100]>>SW1[M4100 DHCP] >>Router>>ASA>>(ISP)
I have no servers onsite (no dhcp), this is a small office depyment about 25 - 35 users. Each user has a PC[VLAN14] and will have an IP Phone[VLAN21].PC will daisy chain from the Phone. We have a cloud based VOIP so this will route via the internet to voice provider. I will also need a separate VLAN 40 for Video Conferencing and VLAN 30 for BioMetrics and IP cameras.
They don not want user the Router or ASA for DHCP, we were informed that the M4100 can meet this requirement, Howver having said that I would be happy just to get the Phones and PC's working together, I have setup DHCP on the M4100[SW1] with the pc hanging off the phone I get a VLAN14 IP (PC) but nothing for phone(vlan21), I am not currently able to test the solution you provided just yet but will do so later today.
Q1: How many DHCP scopes can I setup on switch
I am now familar with just doing plain DHCP for PC addressing.
Q2: How to setup the DHCP so my phones get an IP, both PC and Phone are hanging off the same port on the switch.
Q3: How to do the same for my other Vans30 and 40.
Thank you in advance. :)
DanielZhang
Dec 13, 2017NETGEAR Expert
Hi Sachac,
-->The max of DHCP pool is 15 due to hardware limitation.
-->AutoVoIP with OUI based could support this scenario jperfectly ust as my previous POST.
-->Just like the normal VLAN configuration with Routing interface&DHCP pool.
You can also reference NETGEAR knowledge as below:
Create VLAN routing interface
How-do-I-create-two-VLANs-using-the-web-interface-on-my-managed-switch-to-support-VLAN-routing
Create DHCP server pool for routing interface.
How-do-I-configure-a-DHCP-server-using-the-web-interface-on-my-managed-switch
Thanks,
Daniel.
- sachac14Dec 13, 2017Aspirant
Hi Daniel
Thank you, I will try again later today. Will let you know how this works out.
Hey!, Sorry Daniel
One last question in one of the links you posted it shows how to setup Rip on a routed interface.
How do I setup OSPF?
Thanks for your time. :)
- DanielZhangDec 14, 2017NETGEAR Expert
Hi Sachac,
Please ignore the RIP configuration due to M4100 don't support dynamic router protocol.
I'm sorry that make confuse for you.
Thanks,
Daniel.
