MRINGMAN
Nov 08, 2022Aspirant
M4100-50G is working but cannot find IP address
We are cleaning up all of the equipment at the company I am working with currently and they have a working M4100-50G switch that you can connect and use like a switch should be used. The problem is t...
schumaku
Nov 09, 2022Guru - Experienced User
undoubted, a managed switch cli on a device with no known working and documented configuration has a longer learning curve ... not much magic the community can provide. Many possibilities where the device could hide the click-and-try a web ui for example.
begin with the learning adventure access to all support materials here https://www.netgear.com/support/ enter m4100-50g
Documentation does list
Documentation
Product Data Sheet
CLI Manual (Software Version 10.x)
Hardware Installation Guide
Installation Guide
Software Administration Manual (Software Version 10.x)
Software Setup Manual (Software Version 10.x)
User Manual
Start for example on the Installation Guide
No way around establishing a cli connection, either to the physical serial console, or in-band over ip
Useful could be for example
# show network
or
# clear config
Welcome to the world of managed switches - many similarities on many popular brands by the way. and yes, it's a bigger jump from consumer style click and pray www.
Still struggling? This could help
Unable to access a M4100 series user interface by HTTP or Telnet
MRINGMAN
Nov 10, 2022Aspirant
Can you suggest a terminal emulator for making the connection? Ill give it another shot.
- schumakuNov 10, 2022Guru - Experienced User
You could try putty to facilitate the use of COM ports on Windows. https://www.putty.org/
