MRINGMAN
Nov 08, 2022Aspirant
M4100-50G is working but cannot find IP address
We are cleaning up all of the equipment at the company I am working with currently and they have a working M4100-50G switch that you can connect and use like a switch should be used. The problem is t...
MRINGMAN
Nov 10, 2022Aspirant
Can you suggest a terminal emulator for making the connection? Ill give it another shot.
schumaku
Nov 10, 2022Guru - Experienced User
You could try putty to facilitate the use of COM ports on Windows. https://www.putty.org/
