cstech1
Mar 14, 2019Aspirant
M4100-50G-POE+ Receive Packets Discarded
Hello,
M4100-50G-POE+ ProSafe 48-port Gigabit L2+ Intelligent Edge PoE Managed Switch
Firmware: 10.0.2.26, B1.0.1.1
I have a M4100 currently as configured as a core switch;
The overal...
DaneA
Mar 18, 2019NETGEAR Employee Retired
Hi cstech1,
Welcome to the community! :)
I found out that you have already opened a support ticket (case # 41076306) with NETGEAR Support about your concern described here on your initial post. We will appreciate if you would post updates here about the progress of your support ticket.
DaneA
NETGEAR Community Team
- cstech1Apr 03, 2019Aspirant
After assistance and a couple of suggestions to try, it looks like a switch upgrade will be required as the issue continues.
I will advise the recommended model once confirmed
- cstech1Aug 14, 2019Aspirant
Hello all,
Apologies for the delayed update;
It appears no range of netgear product will support 50 concurrent calls, we are seeking recommendations from other switch vendors.
For now we are trying to work within the limitation of the current setup.
