JohnG101
Apr 16, 2024Follower
M4100-50G-POE+ sFlow with PRTG. Has anyone done this?
M4100-50G-POE+ sFlow with PRTG. Has anyone done this? M4100-50G-POE+ ProSafe 48-port Gigabit L2+ Intelligent Edge PoE Managed Switch, 10.0.1.16, B1.0.0.9 When I setup the M4100 to have this ...
nsskyetech
Apr 30, 2024Aspirant
(M4100-50G-POE+) #show sflow agent
sFlow Version.................................. 1.3;Netgear Inc.;10.0.1.16
IP Address..................................... 172.16.121.5 (this is the IP address of the switch, which should be the agent address)
(M4100-50G-POE+) #show ip interface brief
Interface State IP Address IP Mask Method
(empty) (example show using vlan id) (which vlan is should be used - if any) (does this need to be set?) (if it does, how to set with CLI?)
(M4100-50G-POE+) #show vlan
Maximum VLAN Entries........................... 1024
VLAN Entries Currently in Use.................. 2
VLAN ID VLAN Name VLAN Type
1 default Default
2 Auto VoIP AUTO VoIP
