ronaldpeeters
Feb 01, 2018Aspirant
M4100-50G-POE+(GSM7248P) auto reboot
Is it possible to auto reboot this switch every night? I need to reboot it every 1-2 weeks to keep working.
- ronaldpeetersAspirant
There are 8 access points (WAC720) connected via POE to this switch. Every 1-2 weeks my customer complains that his users cannot connect to internet with their smartphone. When I check the access points (are in ensemble config) they seem to be fine but a reboot of the switch (and via poe also the access points) makes the system working again.
- JohnC_VNETGEAR Employee Retired
Maybe there is something going on inside the network that causes flood for the switch to stop working. May you be able to run syslogs so that we may know what seems to be causing that issue?
