tlex
Nov 21, 2018Aspirant
M4100-50G used to replace my GPON ONT
Good day,
I have a speed question for you today !
I want to replace my isp gpon ont with a dedicated Pfsense virtual machine.
I have setup a dedicated vlan (35-used by Bell Canada) using port 4...
JohnC_V
Nov 27, 2018NETGEAR Employee Retired
Hi tlex,
Welcome to our community! :)
The bandwidth that you have is 1GBp/s and it translates to .125Gbp/s of throughput. This speeds can still handle by the M4100-50G even on the Gigabit Ethernet ports. It is not recommended to use 3rd party modules in our switches. I suggest, you check our own accessories for your M4100.
