tlex
Mar 06, 2017Aspirant
M4100 dhcp reservation
Good day ! So my M4100 is set at 192.168.1.1 I made a dhcp scope (scope1) dynamic for 192.168.1.0 / 255.255.255.0 In the dhcp server setting I made an exclusion from 192.168.1.1 to 192.168.1.99...
DanielZhang
Mar 07, 2017NETGEAR Expert
Hi tlex,
Welcomet to NETGEAR community!:smileyhappy:
Maybe you need to set same configuration for the manual pool as following screenshot.
The Client ID is (01:MAC Address of DHCP client)
The Hardware address is none.
The Host number is the IP address that you want to assigned. (such as: 192.168.1.254)
The Host mask should be same as routing interface(such as: 255.255.255.0)
May the solution help you.
- Feb 20, 2022Retired_Member
