JohnO2016
Nov 16, 2016Aspirant
M4100 Mgmt vlan config
There must be a top-secret sequence of events for this, because I just can't make it work. I need to create a management IP address for this switch and put it on vlan 900. I need to be able to acce...
DanielZhang
Nov 17, 2016NETGEAR Expert
Hi John,
Maybe the Trunk port need to fit peer's configuration in your topology.
In this example, the traffic go out from trunk port will always tag with 900.
Could you share me the port type or VLAN configuration on peer's port?
Anyway it's good to heard your devices working great:smileyhappy:
Daniel.
JohnO2016
Nov 18, 2016Aspirant
The peer is a Cisco C3560. I think its configuration is proper, all the other vlans are working as expected.
interface GigabitEthernet1/4
description L&C MultiP
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 9,10,25,30,33,99,900
switchport mode trunk
