onyangodt
May 11, 2017Aspirant
M4100 Ports 1&2
Greetings, I have recently procured gsm5212p switch and was wondering if it's possible to use the first two ports as regular ports instead of PD ports? is there a configuration that we can use s...
DaneA
May 14, 2017NETGEAR Employee Retired
Hi onyangodt,
Welcome to the community! :)
You can either enable or disable the ability of ports 1 & 2 to deliver power. As reference, kindly read pages 80-83 of the M4100 Series Managed Switch user manual here about PoE Port Configuration.
DaneA
NETGEAR Community Team
- onyangodtMay 14, 2017Aspirant
Greetings,
I have read through those pages before and I still don't see where I can turn ports 1 & 2 into regular ports. I want to be able to hook them up to a computer or other POE device instead of using them to power the switch. I essentially have two unused ports that Id like to use for something other than to power the switch.
- DaneAMay 15, 2017NETGEAR Employee Retired
If ports 1 & 2 of the M4100-D12G-POE+ (GSM5212P) switch is not connected to a PSE (Power Sourcing Equipment) switch and you want it to use it as regular port to connect devices such as PCs, kindly answer the questions below:
a. Is there an error message that appears if you will just use ports 1 & 2 as regular ports?
b. What is the behavior of the port 1 LED light as well as port 2 LED light if you are just using it as regular port?
c. If you will connect a PC to either port 1 or port 2, does it have a connection within the LAN?
d. What is the current firmware version of the M4100-D12G-POE+ (GSM5212P) switch you have?
DaneANETGEAR Community Team
- onyangodtMay 17, 2017Aspirant
I was wondering if we could use ports 1&2 as PoE ports. Having gone through the configuraitons and reading more about it, I can use them as regular ports. I was just wondering if there is a way to use them as PoE ports. I have the latest firmware on the switch and only one LED is on which indicates its communicating with the PC.
- DaneAMay 24, 2017NETGEAR Employee Retired
I inquired your concern about ports 1 & 2 of the M4100-D12G-POE+ switch to a higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, ports 1 & 2 of the M4100-D12G-POE+ switch cannot be used to provide power to PoE devices such as access points and IP phones. Thus, ports 1 & 2 of the M4100-D12G-POE+ switch can either be used as:
a. regular ports
b. power on the M4100-D12G-POE+ switch via a PSE (Power Sourcing Equipment) switch
DaneA
- DaneAJun 04, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further questions.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
