onyangodt
May 11, 2017Aspirant
M4100 Ports 1&2
Greetings, I have recently procured gsm5212p switch and was wondering if it's possible to use the first two ports as regular ports instead of PD ports? is there a configuration that we can use s...
DaneA
May 14, 2017NETGEAR Employee Retired
Hi onyangodt,
Welcome to the community! :)
You can either enable or disable the ability of ports 1 & 2 to deliver power. As reference, kindly read pages 80-83 of the M4100 Series Managed Switch user manual here about PoE Port Configuration.
DaneA
NETGEAR Community Team
onyangodt
May 14, 2017Aspirant
Greetings,
I have read through those pages before and I still don't see where I can turn ports 1 & 2 into regular ports. I want to be able to hook them up to a computer or other POE device instead of using them to power the switch. I essentially have two unused ports that Id like to use for something other than to power the switch.
