acwp521
Jan 17, 2022Aspirant
M4100 vlan/routing help
Hi Netgear network experts, I am looking for some help with configuring a M4100-D12G. I've figured out how to configure vlans but I can't figure out how to get the traffic to route to my internet ...
DaneA
Jan 18, 2022NETGEAR Employee Retired
Welcome to the community! :)
These articles below might help you and use it as your reference guides:
VLAN Routing on Smart Switches
Understanding VLAN Routing on a NETGEAR Smart Switch
DaneA
NETGEAR Community Team
- acwp521Jan 21, 2022Aspirant
Hi Dane,
Thanks for sharing this info. Could you please send me a download-able version of this file so i can print it out?
Thanks.
- acwp521Jan 22, 2022Aspirant
DaneAI made some config changes based on the info you shared. My config is attached. Here's some info regarding the config.
vlan10 - for PC in port 2, 3 or 4
vlan20 - for PC in port 5, 6 or 7
vlan200 - where netgear r7200 is connected in port 8, 9 or 10
IP address for netgear r7200 is 192.168.200.1. If i attach a PC to port 8, 9 or 10 and set the PC IP to 192.168.200.200 with gw 192.168.200.1, i can reach the internet.
If i attach a PC to port 2, 3 or 4 (vlan10) and set IP to 192.168.10.10 with gw 192.168.10.254, i can ping 192.168.200.254. However, i cannot ping 192.168.200.1 and cannot reach the internet.
BTW, i tried to attach a txt file but it won't let me so i am attaching the config as a pdf file.
Could you please review this and see what's missing?
- DaneAFeb 03, 2022NETGEAR Employee Retired
Have you created a static route for VLAN 10 on the router?
Have you created a default route?
Kindly post a diagram of your current network setup (it should be a detailed diagram and not just in words).Regards,
DaneA
- acwp521Feb 10, 2022Aspirant
DaneA I deleted all the configs and started from new. I created the configuration similar to that described in the links you provided. I created the switch configuration with the Netgear M4100-D12G. I created the router configuration using the Netgear r7200. I am still not able to get a PC on one of the vlans to connect to the Internet.
So, I did some troubleshooting and replaced the Netgear r7200 with a different router (different manufacturer) and now the PC is able to connect to the Internet. So, I know the issue is in the Netgear r7200 router configuration (and the M4100 is configured correctly). I know this is not the Netgear r7200 community but if you know of anything to check on the Netgear r7200, please let me know. Otherwise, I can post this question to the Netgear r7200 community.
Thanks for any help you are able to offer.
