acwp521
Jan 17, 2022Aspirant
M4100 vlan/routing help
Hi Netgear network experts, I am looking for some help with configuring a M4100-D12G. I've figured out how to configure vlans but I can't figure out how to get the traffic to route to my internet ...
acwp521
Jan 22, 2022Aspirant
DaneAI made some config changes based on the info you shared. My config is attached. Here's some info regarding the config.
vlan10 - for PC in port 2, 3 or 4
vlan20 - for PC in port 5, 6 or 7
vlan200 - where netgear r7200 is connected in port 8, 9 or 10
IP address for netgear r7200 is 192.168.200.1. If i attach a PC to port 8, 9 or 10 and set the PC IP to 192.168.200.200 with gw 192.168.200.1, i can reach the internet.
If i attach a PC to port 2, 3 or 4 (vlan10) and set IP to 192.168.10.10 with gw 192.168.10.254, i can ping 192.168.200.254. However, i cannot ping 192.168.200.1 and cannot reach the internet.
BTW, i tried to attach a txt file but it won't let me so i am attaching the config as a pdf file.
Could you please review this and see what's missing?
DaneA
Feb 03, 2022NETGEAR Employee Retired
Have you created a static route for VLAN 10 on the router?
Have you created a default route?
Kindly post a diagram of your current network setup (it should be a detailed diagram and not just in words).
DaneA
NETGEAR Community Team
- acwp521Feb 10, 2022Aspirant
DaneA I deleted all the configs and started from new. I created the configuration similar to that described in the links you provided. I created the switch configuration with the Netgear M4100-D12G. I created the router configuration using the Netgear r7200. I am still not able to get a PC on one of the vlans to connect to the Internet.
So, I did some troubleshooting and replaced the Netgear r7200 with a different router (different manufacturer) and now the PC is able to connect to the Internet. So, I know the issue is in the Netgear r7200 router configuration (and the M4100 is configured correctly). I know this is not the Netgear r7200 community but if you know of anything to check on the Netgear r7200, please let me know. Otherwise, I can post this question to the Netgear r7200 community.
Thanks for any help you are able to offer.
