muzicman82
Jun 23, 2020Aspirant
M4200 -> M4300 Multicast Configuration (for NDI / Dante)
Hi all, I am not having any problems currently, but I wanted to run the config by this group and see if there's anything I'm missing or if any tweaks are in order... I have a M4200 with sever...
NeilS
Jun 23, 2020NETGEAR Expert
Hi...
Using 1.1.1.1 and 2.2.2.2 as querier addresses are not a concern as the addresses can be anything you wish, ie., they are not actual IP adreses, but used as part of an election process. Since there can only be a single querier active in the network, and if (as in your case), multiple
queriers are configured, this can trigger an election process. The current active querier will be the switch with the lowest address configured in the querier field.
The M4300 is the primary querier, so in the event of any M4300 downtime, the M4200 would then become the primary IGMP querier, etc.
In order to view Fast-Leave information, the following commands can be used for example:
#show igmpsnooping 1
#show igmpsnooping fast-leave (at port level)
Regarding running Dante and NDI devices on the same VLAN, the best practice recommendation would be to create a seperate VLAN for the Dante devices.
There is a kb available for this available at: https://kb.netgear.com/000060205/M4300-Configuration-Guide-for-Dante-Audio-Devices
Please let us know if you have any further questions.
muzicman82
Jun 24, 2020Aspirant
Thanks for the info... a few follow up questions:
- Am I correct to leave IGMP Snooping Querier Mode to Disable for the M4200 (but enabled on the M4300)? This does give me exactly one querier. I thought there should not be more than one querier on a network, or is that recommendation just for simplicity of not having to properly set up election priorities? I mean, in this sort of environment, if the querier is down, the switch is down and I have more problems....
- Also, I though that with the IGMP proxy mode enabled, there actually isn't a querier elected?
- One recommendation for NDI is to disable QoS? How is that done on these switches, and if I were to setup a VLAN for Dante, I'd need to disable for NDI VLAN and configure QoS for Dante VLAN (I've done this before).
- NeilSJun 24, 2020NETGEAR Expert
Hi,
To answer.
1. Practicality suggests having more than one querier in the event of any failures on the network.
So can make sense to have both switches enabled as querier, but each with higher/lower IP values in the event of an election process.
2. Yes, by configuring all switches (and/or Routers) as IGMP proxy queriers, no designated IGMP querier is elected.
3. QoS isn't enabled by default on either switch model, so no need to specifically disable for NDI devices.
QoS can then be enabled for all Dante devices on the new VLAN.
I hope that helps answer your questions.
- muzicman82Jun 30, 2020Aspirant
Hello,
Still following up here...
I went ahead and configured VLAN 2 to contain only Dante audio devices. I don't expect to need or setup multicast flows, but I have IGMP querier and snooping enabled on this VLAN as well.
I have a few questions regarding the M4300 Dante configuration guide.
- I see where MLD Snooping is enabled for the Dante VLAN in the guide. However, MLD Querier is not enabled. Should it be? Is MLD configured the same way as IGMP? I realize it handles IPv6.
- I do not see in the M4300 where QoS is "disabled" by default. I see it is set to trust-ip-dscp, or is that effectively "disabled" since it is relying on devices to set the flags?
- I am a little lost on how QoS is configured differently for different VLANs, or is it not? Should I follow the steps in the guide and configure the switch QoS settings for Dante even though VLAN 1 will be for management and NDI video? I also realize that the QoS is now being advised for networks with a lot of devices/bandwidth... which I will not have, so is it necessary?
Lastly, I have IGMP Querier enabled on all switches as advised, but in Wireshark, I still see Membership Query messages from both switches. It is less often than the primary switch sends them out. When I check the "2.2.2.2" switch (which should be the backup querier), it does say the Querier status is Non-Querier. So, I guess I am wondering if seeing Membership Queries from both switches is normal or if I should disable the querier on the non-primary switch.
Also, I'm getting between 167-235ms in NDI video latency. Is it possible that the switch is adding some of this latency? I did change one NDI camera to unicast and it did not affect the video latency.
