Khansen_dk
Sep 20, 2023Aspirant
M4250 - 404 Not Found when trying to enter the Main UI
Hi all, We have a bunch of M4250 switches that have been working fine for a year or so. Suddenly, we can't login into the Main UI (classic configuration) one one of them. When we click the Mai...
Khansen_dk
Hi Kurt,
The switch has a static IP address and my IP is in the same range and subnet as the switch.
I have tried resettings the switch using the ezconfig, but it didn't make any difference.
I can ping and login to the switch via the AV UI - no problem.
It is just the Main UI that is unavailable.
Best regards,
Kim
Edyx
Nov 19, 2023Aspirant
Hi guys,
Same problem here, after updating to firmware 13.0.4.17, I cannot access anymore to the main UI, and I noticed also that when save and upload a configuration file some configuration doesn't update correctly. I also checked the ".cfg" file and it seems that everything is ok, I'll post it here:
Spoiler
!AVUI Configuration:
!<timezone>
!{"switchConfig":{"clock":{"timezone":""}}}
!</timezone>
!<template>
!{"name": "Video with AES67 audio","custom":false,"activation":true,"description":"To connect IP Video devices and their controller. Audio AES67 supported at the same time in the same VLAN. Supported devices include NVX, AMX, ZeeVee, Aurora, Kramer, Atlona, ATEN, LibAV, Visionary, Wyrestorm, Extron NAV, Dante AV, SDVoE & etc.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":true,"qos": [{"type":1,"codePoint":34,"priority":4},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":56,"priority":6},{"type":2,"priority":6,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2}]}
!{"name": "Waves Soundgrid","custom":false,"activation":true,"description":"To connect IP Audio SoundGrid devices and their controllers.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":false,"MTU":true,"qos":[]}
!{"name": "Shure Converged Audio and Control Network","custom":false,"description":"To connect Shure devices requiring audio and control traffic on a single VLAN. Compatible with Dante, AES67, QSYS, and Biamp Dante devices.","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":false,"qos":[{"type": 1,"codePoint": 34,"priority": 4},{"type": 1,"codePoint": 46,"priority": 5},{"type": 1,"codePoint": 56,"priority": 6},{"type":2,"priority":6,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2}]}
!{"name": "Visionary AV Network","custom":false,"activation":true,"color":{"value":"#4381CF", "modifiable":true},"description":"To connect Visionary AV systems. For quick auto detection and for ease of configuration.","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":true,"macfilter1":true,"qos": []}
!{"name": "Video","custom":false,"activation":true,"description":"To connect IP Video devices and their controller. Audio can be sent and received using another VLAN tag in another profile simultaneously. Supported devices include NVX, AMX, ZeeVee, Aurora, Kramer, Atlona, ATEN, LibAV, Visionary, Wyrestorm, Extron NAV, Dante AV, SDVoE & etc.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":false,"MTU":true,"qos":[]}
!{"name": "Crestron DigitalMedia AV Network","custom":false,"activation":true,"color":{"value":"#0099DB", "modifiable":true},"description":"To connect Crestron DM NVX (video), Crestron DM NAX (audio), Creston 1 Beyond cameras (NDI), PCs, and other Crestron Control network devices.","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"flowControl":true,"MTU":false,"poe":true,"qos":[]}
!{"name": "Audio AES67","custom":false,"activation":true,"description":"To connect IP Audio AES67 devices and their controller","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":true,"qos": [{"type":1,"codePoint":34,"priority":4},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":56,"priority":6},{"type":2,"priority":4,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":6,"schedulerType":2}]}
!{"name": "Audio Dante","custom":false,"activation":true,"description":"To connect IP Audio Dante devices and their controller","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":true,"qos":[{"type": 1,"codePoint": 48,"priority": 5},{"type":1,"codePoint":56,"priority":6},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":8,"priority":2},{"type":2,"priority":2,"schedulerType":2},{"type":2,"priority":6,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2}]}
!{"name": "Lighting","custom":false,"activation":true,"description":"To connect sACN, Art-Net, and MA-Net3 network devices, for controlling lighting equipment.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":false,"MTU":true,"storm":false}
!{"name": "Data","custom":false,"activation":true,"description":"To connect PCs and other Control network devices. CobraNet is supported in a VLAN other than VLAN 1.","multicast": {"igmp": false,"igmpPlug": false},"AVB":false,"PTP":false,"MTU":true}
!{"name": "Audio Video AVB","custom":false,"activation":true,"description":"To connect IP Audio Video AVB devices and their controller.","multicast": {"igmp": false,"igmpPlug": false},"AVB":true,"PTP":false,"MTU":false,"qos":[]}
!{"name": "NUCLEUS Converged AV Network","custom":false,"activation":true,"defaultName":{"name":"NUCLEUS","modifiable":true},"color":{"value":"#055071", "modifiable":true},"description":"To connect EvertzAV NUCLEUS Session Manager and UXP gateways on a single converged network.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":false,"MTU":true,"qos":[]}
!{"name": "Video with Q-SYS audio","custom":false,"activation":true,"description":"To connect IP Video devices and their controller. Audio Q-SYS supported at the same time in the same VLAN. Supported devices include NVX, AMX, ZeeVee, Aurora, Kramer, Atlona, ATEN, LibAV, Wyrestorm, Extron NAV, Dante AV, SDVoE & etc.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":false,"macfilter":true,"qos":[{"type":1,"codePoint":34,"priority":4},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":26,"priority":3},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2},{"type":2,"priority":3,"schedulerType":2}]}
!{"name": "Video with Dante audio","custom":false,"activation":true,"description":"To connect IP Video devices and their controller. Audio Dante supported at the same time in the same VLAN. Supported devices include NVX, AMX, ZeeVee, Aurora, Kramer, Atlona, ATEN, LibAV, Visionary, Wyrestorm, Extron NAV, Vaddio EasyIP, Dante AV, SDVoE & etc.","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":true,"qos": [{"type": 1,"codePoint": 48,"priority": 5},{"type": 1,"codePoint": 56,"priority": 6},{"type": 1,"codePoint": 46,"priority": 5},{"type": 1,"codePoint": 8,"priority": 2},{"type": 1,"codePoint": 34,"priority": 4},{"type":2,"priority":6,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2},{"type":2,"priority":2,"schedulerType":2}]}
!{"name": "Shure Split Audio and Control Network","custom":false,"description":"To connect Shure devices requiring separation of audio and control traffic into different VLANs. Compatible with Dante, AES67, QSYS, and Biamp Dante devices.","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":false,"qos":[{"type": 1,"codePoint": 34,"priority": 4},{"type": 1,"codePoint": 46,"priority": 5},{"type": 1,"codePoint": 56,"priority": 6},{"type":2,"priority":6,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2}]}
!{"name": "Video NDI4","custom":false,"description":"To connect NDI Version 4 (mTCP) video devices and cameras.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":false,"flowControl":true,"MTU":false,"qos":[]}
!{"name": "Audio Q-SYS","custom":false,"activation":true,"description":"To connect IP Audio Q-SYS devices and their controller","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":false,"macfilter":true,"qos":[{"type":1,"codePoint":34,"priority":4},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":26,"priority":3},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2},{"type":2,"priority":3,"schedulerType":2}]}
!{"name": "Video NDI5 with Dante,Q-Sys or AES67 audio","custom":false,"activation":true,"description":"To connect NDI Version 5 (RUDP) video devices and cameras. Audio Dante, Q-SYS or AES67 is supported at the same time in the same VLAN.","multicast": {"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"flowControl":true,"MTU":false,"macfilter":true,"qos":[{"type":1,"codePoint":34,"priority":4},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":26,"priority":3},{"type":2,"priority":5,"schedulerType":2},{"type":2,"priority":4,"schedulerType":2},{"type":2,"priority":3,"schedulerType":2}]}
!{"name": "Sonos","custom":false,"activation":true,"description":"To connect the Sonos smart home sound system.","multicast": {"queryInterval": 30,"igmp": true,"igmpPlug": true},"AVB":false,"PTP":true,"MTU":true,"qos":[{"type": 1,"codePoint": 48,"priority": 5},{"type":1,"codePoint":56,"priority":6},{"type":1,"codePoint":46,"priority":5},{"type":1,"codePoint":8,"priority":2},{"type":2,"priority":2,"schedulerType":2},{"type":2,"priority":6,"schedulerType":2},{"type":2,"priority":5,"schedulerType":2}], "Sonos":true}
!</template>
!<vlan>
!vlan:1{"color":"#000000","profileName":"Default","profileType":"Data", "vlanType":1}
!vlan:2{"color":"#962EC2","profileName":"NDI","profileType":"Video NDI5 with Dante,Q-Sys or AES67 audio", "vlanType":1}
!vlan:3{"color":"#3DEE0C","profileName":"DANTE","profileType":"Audio Dante", "vlanType":1}
!vlan:4{"color":"#0585FD","profileName":"LUCI","profileType":"Lighting", "vlanType":1}
!vlan:5{"color":"#F70707","profileName":"INTERCOM","profileType":"Data", "vlanType":1}
!vlan:6{"color":"#01F6D5","profileName":"DANTE SECONDARY","profileType":"Audio Dante", "vlanType":1}
!vlan:13{"color":"#FF7300","profileName":"VIDEO_1","profileType":"Data", "vlanType":1}
!vlan:14{"color":"#FF0000","profileName":"VIDEO_2","profileType":"Data", "vlanType":1}
!vlan:15{"color":"#FFEE00","profileName":"VIDEO_3","profileType":"Data", "vlanType":1}
!vlan:16{"color":"#E6FF00","profileName":"VIDEO_4","profileType":"Data", "vlanType":1}
!vlan:17{"color":"#CF0C0C","profileName":"VIDEO EXTENDER 5","profileType":"Data", "vlanType":1}
!</vlan>
!<shure>
!</shure>
!Current Configuration:
!System Description "M4250-10G2XF-PoE+ 10x1G PoE+ 240W and 2xSFP+ Managed Switch, 13.0.4.17, 1.0.0.11"
!System Software Version "13.0.4.17"
!System Up Time "0 days 0 hrs 23 mins 34 secs"
!Additional Packages QOS,Multicast,IPv6,IPv6 Management,Routing
!Current SNTP Synchronized Time: SNTP Last Attempt Status Is Not Successful
vlan database
vlan 2-6,13-17
vlan name 2 "NDI"
vlan name 3 "DANTE"
vlan name 4 "LUCI"
vlan name 5 "INTERCOM"
vlan name 6 "DANTE SECONDARY"
vlan name 13 "VIDEO_1"
vlan name 14 "VIDEO_2"
vlan name 15 "VIDEO_3"
vlan name 16 "VIDEO_4"
vlan name 17 "VIDEO EXTENDER 5"
set igmp-plus 2
set igmp-plus 3
set igmp-plus 4
set igmp-plus 6
vlan routing 1 1
exit
ip http port 49151
configure
username "admin" password $6$kkdjfYAs1PvE94tT$IyMtNJ0.bqlybDWBXt.pNQPS7b3DRA0lmiisC727uY6xDNt9rFKGy9NAUZR1d5OOpW7R9IYmIcNV5liG7gebU/ encryption-type sha512 level 15 encrypted
line console
exit
line telnet
exit
line ssh
exit
no port-channel auto
port-channel auto load-balance 1
ip access-list NET-BLOCK
exit
set igmp querier query-interval 30
classofservice ip-dscp-mapping 8 2
classofservice ip-dscp-mapping 26 3
classofservice ip-dscp-mapping 34 4
classofservice ip-dscp-mapping 46 5
classofservice ip-dscp-mapping 48 5
classofservice ip-dscp-mapping 56 6
cos-queue strict 2 3 4 5 6
interface 0/1
vlan pvid 3
vlan participation exclude 1
vlan participation include 3
ptp clock e2e-transparent
no poe
exit
interface 0/2
vlan pvid 6
vlan participation include 6
no poe
exit
interface 0/3
mtu 1500
vlan pvid 2
vlan participation include 2
no poe
flowcontrol symmetric
exit
interface 0/4
vlan pvid 13
vlan participation include 13
no poe
exit
interface 0/5
vlan pvid 14
vlan participation include 14
no poe
exit
interface 0/6
vlan pvid 15
vlan participation include 15
no poe
exit
interface 0/7
vlan pvid 16
vlan participation include 16
no poe
exit
interface 0/8
vlan pvid 5
vlan participation include 5
no poe
exit
interface 0/9
no storm-control broadcast
vlan pvid 4
vlan participation include 4
exit
interface 0/10
vlan pvid 17
vlan participation include 17
exit
interface 0/11
exit
interface vlan 1
routing
ip address dhcp
exit
router rip
exit
exit
ip http secure-port 49152
!<timezone>
!</timezone>
!<template>
!</template>
!<vlan>
!</vlan>
!<shure>
!</shure>
vlan database
vlan 2-6,13-17
vlan name 2 "NDI"
vlan name 3 "DANTE"
vlan name 4 "LUCI"
set igmp-plus 2
set igmp-plus 3
set igmp-plus 4
set igmp-plus 6
vlan routing 1 1
exit
ip http port 49151
configure
line console
exit
line telnet
exit
line ssh
exit
exit
interface 0/1
vlan pvid 3
no poe
exit
interface 0/2
vlan pvid 6
no poe
exit
interface 0/3
mtu 1500
vlan pvid 2
no poe
exit
interface 0/4
vlan pvid 13
no poe
exit
interface 0/5
vlan pvid 14
no poe
exit
interface 0/6
vlan pvid 15
no poe
exit
interface 0/7
vlan pvid 16
no poe
exit
interface 0/8
vlan pvid 5
no poe
exit
interface 0/9
vlan pvid 4
exit
interface 0/10
vlan pvid 17
exit
interface 0/11
exit
interface vlan 1
routing
ip address dhcp
exit
router rip
exit
exit
As you can see in this .cfg file there is a vlan 17, named:"VIDEO EXTENDER 5", associated to port 10. The problem is that when I upload this .cfg file on the switch there is nothing on port 10!
I'm not an expert IT manager, so maybe I'm doing something wrong, if you any advice please reply to this post!
Thanks!
- schumakuNov 19, 2023Guru - Experienced User
Please start with a new thread instead of capturing another old thread, focusing on a different subject.
Briefly looking over your config shows 10 ports, copper each configured as an access port for a dedicated VLAN each, and fiber port 11 is configured for VLAN 1 only, but not as an untagged aces port, much more likely tagged only.
Completely in the dark how the other ports should ever talk to a probably existing environment on VLAN 2-6 and 13-17 (where VLAN 2 isn't in use anywhere). Similar, the extender on port 10 is an access port for VLAN 17. What exactly you expect to "see" on port 10 is outside of my crystal ball. How should this be related to the default management VLAN 1?
