Gg72
Oct 09, 2022Follower
M4250 routing multicast ptp 224.0.1.129
Hi everyone, Do you know if multicast intervlan routing of ptp (224.0.1.129) is possible? I try with pim sm and multicast route static but it doesn’t work. If you have the solution?
michaelkenward
Oct 09, 2022Guru - Experienced User
You have an M4250, one of Netgear's managed switches. You wont find m,any knowledgeable users in a section given over to Nighthawk routers.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
