StuartD
Sep 07, 2024Aspirant
M4250 Unable to edit default data profile GSM4210PD 8 Port
I’d like to edit the default data profile so that it gives out ip addresses in the 192.168.0.x range. I think I’m doing it correctly, I hit apply then save but it never works and just defaults back to...
ErwinL
Sep 08, 2024NETGEAR Moderator
Hello StuartD
And welcome to the NETGEAR Community! 🙂
Would you mind providing us a clear screenshot of your issue? Are you trying to use the device for AV systems?
Have a lovely day,
Erwin
Netgear Team
StuartD
Sep 11, 2024Aspirant
Hi Erwin,
Thanks for getting back. I’m away from that unit right now so unable to provide any screen shots.
I have a simple project where I would like to change the default Data profile so that it gives out ip addresses in the 192.168.0.x range.
I’ve gone to edit the default profile and have done the following:
1. Clicked the button to edit the IP Setting
2. Selected DHCP from the dropdown
3. Set the router address as 192.168.0.1
4. Set a pool as 192.168.0.100 to 200
5. Set the DNS server to be 192.168.0.1
6. Click apply and save the config
These settings never save, when I look at the profile it’s just defaulted back, IP settings say none.
I thought I might need to change the management address of the router to 192.168.0.1 but event that setting doesn’t change.
Any help appreciated.
Thanks
Stuart
Thanks
Stuart
- ErwinLSep 19, 2024NETGEAR Moderator
Hello StuartD
Are you trying to modify the profile from the "Main UI or from "AV UI"? Can you provide a screenshot of it?
Have a lovely day,
Erwin
Netgear Team- StuartDSep 19, 2024Aspirant
Hi Erwin,
Im using the AV UI. Im still away from the unit so can't provide a screenshot.
Thks
Stuart
