lchambers84
Dec 09, 2019Aspirant
M4300 - Firmware Issue
Hello, I am wondering if someone can help with this issue I am having we have recently updated the firmware on our switches to 12.0.9.3 whcih are M4300 and have managed to do this on a majority o...
- Dec 11, 2019
kevin_hong Hello thanks for your response but I have managed to get this sorted through Netgear tech support the number that the error was displaying has been confirmed that the flash caused the issue - It was the only switch that when it was flashed to the latest firmware failed the other batch of switches so far have went successfully so hopefully 1 having the issue out of what we have isn't bad just an inconvience but the response from Netgear has been great.
kevin_hong
Dec 10, 2019Apprentice
Hi lchambers84,
Thank you for your feedback,
Could you please answer some of my questions for this issue?
1.Are you switch(M4300) stacked ? What M4300 models do you have?
2.Which version was upgrade to 12.0.9.3? any configuration on switch?
BTW: it would be better if you can provide Tech support file
Thank you
lchambers84
Dec 11, 2019Aspirant
