CharlesB89
Jan 29, 2019Aspirant
M4300 - How to configure the management IP to be the same as the IP of the switch?
Switch that I am trying to configure: M4300, firm 12.0.4.8 - Network Design - modem, firewall, switches.
I set IP of the switch to 10.0.4.x/24 and gw: 10.0.4.1
I want to be able to reach the ...
- Jan 30, 2019
You may try it. For me, since your current firmware version is a few versions away from the latest one, it would be better to do the firmware upgrade in a ladderized manner.
DaneA
NETGEAR Community Team
DaneA
Jan 29, 2019NETGEAR Employee Retired
Hi CharlesB89,
Welcome to the community! :)
Let us upgrade the firmware to the latest version in a ladderized manner. First, upgrade the firmware from v12.0.4.8 to v12.0.4.9. Then, upgrade the firmware from v12.0.4.9 to 12.0.6.6 and so on until you reach the latest firmware which is v12.0.7.10. You can download the M4300 firmware versions here. Perform a factory reset on the switch after upgrading the firmware to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, check if you will encounter the same problem.
DaneA
- CharlesB89Jan 29, 2019Aspirant
Question, can I just upgrade the firmware from 12.0.4.8 directly to 12.0.7.10?
- DaneAJan 30, 2019NETGEAR Employee Retired
DaneA
