ClemensD
Feb 06, 2020Tutor
M4300 - interface status err-disabled
Hello, just one question regarding the diagnosis of interfaces which are in err-disabled state. In case of a dai or ip source guard violation the related port will be shut down. The affected...
kevin_hong
Feb 13, 2020Apprentice
Hi ClemensD ,
Welcome to community,
You can using "show port all" by CLI or Port configuration by Gui to check the interface state
show port all
Admin Physical Physical Link Link LACP Flow Stack
Intf Type Mode Mode Status Status Trap Mode Mode Capable
2/5/2 D-Disable Auto Down Enable Enable Disable Yes
Thank you
