bbs2web
Jun 30, 2021Guide
M4300 - MACs age out instantly with STP enabled (tcnguard is enabled)
We appear to have hit an issue whereby MAC addresses associated with an interface configured in dot1q-tunnel (double VLAN) mode, whereby MACs age out instantly and therefor results in unicast traffic being broadcast to all VLAN member ports.
We originally observed this behaviour in 12.0.11.15 and can confirm that the problem also occurs after having upgraded the stack of 2 x M4300-24X24F and 2 x M4300-96X to 12.0.13.7.
The problem occurs the moment we enable spanning tree on the interface. I'm under the impression that 'guard root' and 'tcnguard' should remediate against these issues but presume a bug as a TCN, even if it bypasses the TCN guard filter, shouldn't result in MAC addresses aging out immediately.
Herewith the interface configuration and MAC table when things are working as expected:
(M4300-24X24F) #show running-config interface 2/0/21 !Current Configuration: ! interface 2/0/21 description 'dot1q-tunnel vlan 11' spanning-tree guard root spanning-tree tcnguard no spanning-tree port mode mtu 12270 vlan pvid 11 vlan ingressfilter vlan participation auto 1 vlan participation include 11 exit (M4300-24X24F) #show mac-addr-table vlan 11 Address Entries Currently in Use............... 5483 MAC Address Interface Status ----------------- ----------------------- ------------ 00:C0:89:21:E9:20 2/0/21 Learned 00:C0:89:3D:52:8C 2/0/21 Learned 02:BD:36:44:92:8D lag 22 Learned 02:CE:14:AD:F7:A0 lag 22 Learned 08:55:31:30:21:C8 2/0/21 Learned 08:55:31:C1:1D:FF 2/0/21 Learned 4C:5E:0C:39:03:24 2/0/21 Learned 4C:5E:0C:E1:52:E4 lag 22 Learned 74:4D:28:05:76:C0 2/0/21 Learned 74:4D:28:07:A9:62 2/0/21 Learned 74:4D:28:07:B1:28 2/0/21 Learned C4:AD:34:6A:49:75 lag 22 Learned C4:AD:34:71:A6:8F 2/0/21 Learned C4:AD:34:85:35:2E 2/0/21 Learned C4:AD:34:85:35:30 2/0/21 Learned C4:AD:34:BD:62:9E 2/0/21 Learned CC:2D:E0:BD:4F:FC lag 28 Learned CC:2D:E0:E4:B3:86 lag 26 Learned D4:CA:6D:01:CB:BF 2/0/21 Learned E4:8D:8C:3A:E0:A4 lag 22 Learned
The mac address table remains in this state, without churn, until we enable STP on the interface. In the following examples we ran the 'show mac-addr-table vlan 11' command in quick succession (up arrow key and then enter) with 1 second or less time between each command. The system log shows no event being logged when this behaviour exhibits itself:
(M4300-24X24F) #configure (M4300-24X24F) (Config)#interface 2/0/21 (M4300-24X24F) (Interface 2/0/21)#spanning-tree port mode (M4300-24X24F) (Interface 2/0/21)#end (M4300-24X24F) #show mac-addr-table vlan 11 Address Entries Currently in Use............... 5474 MAC Address Interface Status ----------------- ----------------------- ------------ 02:BD:36:44:92:8D lag 22 Learned 02:CE:14:AD:F7:A0 lag 22 Learned 08:55:31:30:21:C8 2/0/21 Learned 4C:5E:0C:E1:52:E4 lag 22 Learned C4:AD:34:6A:49:75 lag 22 Learned CC:2D:E0:BD:4F:FC lag 28 Learned CC:2D:E0:E4:B3:86 lag 26 Learned E4:8D:8C:3A:E0:A4 lag 22 Learned (M4300-24X24F) #show mac-addr-table vlan 11 Address Entries Currently in Use............... 5473 MAC Address Interface Status ----------------- ----------------------- ------------ 02:BD:36:44:92:8D lag 22 Learned 02:CE:14:AD:F7:A0 lag 22 Learned 4C:5E:0C:E1:52:E4 lag 22 Learned C4:AD:34:6A:49:75 lag 22 Learned CC:2D:E0:BD:4F:FC lag 28 Learned CC:2D:E0:E4:B3:86 lag 26 Learned E4:8D:8C:3A:E0:A4 lag 22 Learned (M4300-24X24F) #show mac-addr-table vlan 11 Address Entries Currently in Use............... 5476 MAC Address Interface Status ----------------- ----------------------- ------------ 02:BD:36:44:92:8D lag 22 Learned 02:CE:14:AD:F7:A0 lag 22 Learned 4C:5E:0C:39:03:24 2/0/21 Learned 4C:5E:0C:E1:52:E4 lag 22 Learned 74:4D:28:07:A9:62 2/0/21 Learned C4:AD:34:6A:49:75 lag 22 Learned CC:2D:E0:BD:4F:FC lag 28 Learned CC:2D:E0:E4:B3:86 lag 26 Learned D4:CA:6D:01:CB:BF 2/0/21 Learned E4:8D:8C:3A:E0:A4 lag 22 Learned (M4300-24X24F) #show logging buffered Buffered (In-Memory) Logging : enabled Buffered Logging Wrapping Behavior : On Buffered Log Count : 3071 Buffered Log Threshold (lines) : 160 <13> Jun 30 22:34:55 M4300-24X24F-1 CMDLOGGER[emWeb]: cmd_logger_api.c(83) 3000695 %% CLI:154.119.67.52:davidh:show mac-addr-table vlan 11 <13> Jun 30 22:34:54 M4300-24X24F-1 CMDLOGGER[emWeb]: cmd_logger_api.c(83) 3000691 %% CLI:154.119.67.52:davidh:show mac-addr-table vlan 11 <13> Jun 30 22:34:54 M4300-24X24F-1 CMDLOGGER[emWeb]: cmd_logger_api.c(83) 3000690 %% CLI:154.119.67.52:davidh:show mac-addr-table vlan 11 <13> Jun 30 22:34:50 M4300-24X24F-1 TRAPMGR[dot1s_task]: traputil.c(795) 3000676 %% Spanning Tree Topology Change Initiated: 0, Interface: 2/0/21 <13> Jun 30 22:34:50 M4300-24X24F-1 TRAPMGR[dot1s_task]: traputil.c(795) 3000675 %% Spanning Tree Topology Change: 0, Unit: 1 <13> Jun 30 22:34:49 M4300-24X24F-1 CMDLOGGER[emWeb]: cmd_logger_api.c(83) 3000671 %% CLI:154.119.67.52:davidh:spanning-tree port mode <13> Jun 30 22:34:36 M4300-24X24F-1 CMDLOGGER[emWeb]: cmd_logger_api.c(83) 3000631 %% CLI:154.119.67.52:davidh:interface 2/0/21 <13> Jun 30 22:34:32 M4300-24X24F-1 CMDLOGGER[emWeb]: cmd_logger_api.c(83) 3000614 %% CLI:154.119.67.52:davidh:configure
No RepliesBe the first to reply
