PDunnington's avatar
PDunnington
M4300-12X12F replacing M7100-24X - Wireless Access Points not working
Hi Everyone, I'm attempting to replace our ageing M7100-24X with a M4300-12X12F (XSM4324S) which I bought just over two weeks ago. I haven't contacted support yet as I'm hoping that perhaps someon...
  • schumaku's avatar
    schumaku
    May 26, 2022
    Paul,
    As you mentioned the data is flowing over that MiNT tunnel between AP and controller - that is making use of 24577/UDP (wally brain is awake again) - I guess trouble with discovery and management is more on that special ether-type 0x8783 for L2 than on UDP used for L3 (routed connections).
    Some sniffing would easily proof if the switch does fail to deal with ether-type 0x8783. That's why I point on the Netgear switch engineering resp. fellow Laurent Masia. 8-)
    -Kurt
ProSupport for Business
