Trollpaw
Jul 07, 2019Aspirant
M4300-12X12F (XSM4324S) needs reboot to access admin interface
Hello. I have a strange issue with a couple of our Netgear Switches. They're of model m4300-12x12f(XSM4324S). They're being used as core switches in the different houses in a business park. ...
DaneA
Jul 08, 2019NETGEAR Employee Retired
Welcome to the community! :)
I suggest you try to update the firmware of all 3 M4300-12X12F switches to the latest version which is v12.0.7.15. You can download it here. Then, check if the same problem will occur.
You may want to perform a factory reset on the switch after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version.
DaneA
NETGEAR Community Team
- TrollpawJul 08, 2019Aspirant
Thank you for the answer.
I will try that.
In the meantime, do you know if this is something known to happen in previous firmwares?
Regards
Stoffe Eriksson
