Trollpaw
Jul 07, 2019Aspirant
M4300-12X12F (XSM4324S) needs reboot to access admin interface
Hello. I have a strange issue with a couple of our Netgear Switches. They're of model m4300-12x12f(XSM4324S). They're being used as core switches in the different houses in a business park. ...
DaneA
Jul 08, 2019NETGEAR Employee Retired
Welcome to the community! :)
I suggest you try to update the firmware of all 3 M4300-12X12F switches to the latest version which is v12.0.7.15. You can download it here. Then, check if the same problem will occur.
You may want to perform a factory reset on the switch after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version.
DaneA
NETGEAR Community Team
Trollpaw
Jul 08, 2019Aspirant
Thank you for the answer.
I will try that.
In the meantime, do you know if this is something known to happen in previous firmwares?
Regards
Stoffe Eriksson
- DaneAJul 09, 2019NETGEAR Employee Retired
As far as I have checked with the NETGEAR Support Team, there are no known issue as per described here in the initial post on the previous firmwares.
DaneA
- TrollpawJul 11, 2019Aspirant
I got another question if that is alright, in regards to this.
Is it alright to use the old config-file after the update and factory reset, or must I do everything from scratch?
I mean, backup configuration, update, factory reset, reload configuration.
or should i do it another order? or not use the backup config at all after the update?
Regards
Stoffe Eriksson
