Trollpaw
Jul 07, 2019Aspirant
M4300-12X12F (XSM4324S) needs reboot to access admin interface
Hello. I have a strange issue with a couple of our Netgear Switches. They're of model m4300-12x12f(XSM4324S). They're being used as core switches in the different houses in a business park. ...
DaneA
Jul 09, 2019NETGEAR Employee Retired
As far as I have checked with the NETGEAR Support Team, there are no known issue as per described here in the initial post on the previous firmwares.
DaneA
NETGEAR Community Team
Trollpaw
Jul 11, 2019Aspirant
I got another question if that is alright, in regards to this.
Is it alright to use the old config-file after the update and factory reset, or must I do everything from scratch?
I mean, backup configuration, update, factory reset, reload configuration.
or should i do it another order? or not use the backup config at all after the update?
Regards
Stoffe Eriksson
- DaneAJul 21, 2019NETGEAR Employee Retired
Just want to inform you that M4300 firmware v12.0.7.17 has been released. Kindly check its bug fixes and known issues as well as you can download it here.
I suggest you to upgrade the firmware of your M4300 switch/es to firmware v12.0.7.17 and observe if the same problem occurs.
DaneA
NETGEAR Community Team- jg1Jul 29, 2019Aspirant
12.0.7.17 does not fix the issue. The swtich still reboots as soon as the web gui is accessed.
- msiJul 29, 2019Luminary
I'd recommend opening a case with Netgear and also to configure a remote syslog server where the affected switches can send their logs to. This has proven useful for analysis of post-mortems overall since you will at least catch the logs until the point where the switch crashes and reboots. Configuring a Linux box with rsyslog to receive syslog from remote systems is pretty easy to accomplish, there are plenty of examples and tutorials on the internet.
I don't use the WebUI on our M4300 as the access to the management VLAN is pretty restrictively configured in my case and I prefer SSH, however I actually need to run 12.0.7.17 due to stacking fixes that were quite annoying (in 12.0.7.12) or actually problematic (12.0.7.15) that have been fixed with 12.0.7.17
