Mjh2157
Dec 23, 2021Tutor
M4300-16X (XSM4316PA) and ORBI RBK854 CONFIGURATION
Hi, The auto fill menu for the model numbers on this post doesn't have my models, so below is my equipment: Modem - Nighthawk CM2000 Multi-gig Router with 3 Satelites over ethernet backhaul ...
- Dec 23, 2021
Can't find any complete specs of this 828LM LiftMaster Internet Gateway. They only talk of "Ethernet". In case this is a simple 10 Mb/s Ethernet port (plenty of performance for a door opener), the M4300-16X (XSM4316PA) does support Fast Ethernet (100 Mb/s) and up, classic 10 Mb/s Ethernet won't bring up a link. This is fine on the Orbi however if I have it right. I'd suggest to try a simple small non-managed switch in between the M4300 and the LiftMaster for a test or work-around.
schumaku
Dec 23, 2021Guru - Experienced User
- Mjh2157Dec 23, 2021Tutor
Thank you very much, will do. Have a Happy and Healthy New Year
Best Regards,
Matt
- schumakuDec 23, 2021Guru - Experienced User
Oh not tried yet? It's pure guess for the moment only. Let us know on how this is progressing.
Wish you a wonderful mas and a happy new year!
-Kurt
Hi,
I plugged an old netgear GS108 10/100 mb switch into the same switch port on my M4300 that wasn't activating for the 828LM device. The port lit up instantly. I then plugged the 828LM device into the GS108 and it connected at 10 mb/s and started working right away. It's great to have it working, but it's disappointing to need a second "lesser" switch to make it work. Thank you for th quick solution. I wish I could make one of the ports on my M4300 work at 10 MB/S and not need to run a second switch.
Best Regards,
Matt
